1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
92 Civic sometimes doesn't start!
Old Aug 30, 2013
Duh_Duste's Avatar
Duh_Duste is an unknown quantity at this point
This has been going on for the last several months. At first I thought the car was vapor locking because it seemed to be not starting when hot outside, no matter if i had driven the car or not that day, but has since done it when it has been cold outside. There are days that it is hot and it will start fine all day long no matter how many stops I make so then I figured well maybe it was the fuel filter because at times I will put gas in it and wont start so figured it was stirring up gunk in filter. I have had many people tell me it sounds like a relay over the filter. I just have no idea what relay. I have also had more than one person tell me is timing belt going bad. The thing is it always starts again, sometimes with cranking it over 20 times sometimes 5 and sometimes I just have to let it sit for several hours and it will start again. Sometimes to get it restarted i have to let it crank over for 30 to 45 sec before it will start other times it will crank over it i just try cranking it repeatedly a couple of times. I am trying to do this the cheapest route possible cuz am jobless at the moment so if any one can tell me with they feel the problem may be I would be great full before it decides to leave me stranded for good!!
Old Aug 30, 2013
Fliptard's Avatar
Fliptard will become famous soon enoughFliptard will become famous soon enough
Re: 92 Civic sometimes doesn't start!
Main relay. does the fuel pump prime everytime the key is turned on? do u hear a click under the dash?
Old Aug 30, 2013
Duh_Duste's Avatar
I have never honestly ever heard it click but I would think that it does cuz when it doesnt start and i pump the gas when I do finally get it started it smells like gas so it is obviously making its way up to the filter at least.
Old Aug 30, 2013
Fliptard's Avatar
you need to get a fuel pressure tester and make sure your getting enough, if any pressure to the fuel filter/rail.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Richkid23
Apr 19, 2015 12:53 PM
tattedlariat
Apr 17, 2015 03:26 AM
mrohitredd
Apr 15, 2015 08:13 PM
SSMatey
Apr 13, 2015 06:09 PM
