1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
94 civic y8 swap TROUBLE HELP
Old Jul 27, 2013
94simplyclean's Avatar
94simplyclean is an unknown quantity at this point
ok so I have a 94 civic with y8 swap,obd1 wiring harness and p28 ecu,it was breaking up when I hit mid pedal so I changed the dizzy and now it cuts off randomly;I've swapped another dizzy on it and it does the same thing and the cel is 8 meaning tdc sensor,I'm lost and don't know what to do pls help,thanks in advance
Old Jul 27, 2013
Re: 94 civic y8 swap TROUBLE HELP
can anyone shed some light on this for me pls I need to get my car running
Old Jul 28, 2013
Jeremy71667's Avatar
Jeremy71667 is an unknown quantity at this point
How's the timing? Can you put the old dizzy back on and see if it goes back to your mid pedal problem?
Old Jul 28, 2013
And have you checked the idle air control valve?
Old Jul 28, 2013
timing is dead on and I can't put the old one back on bc it's gone;and idle air control valve is bad but that won't shut the car off in the middle of driving it
Old Aug 5, 2013
Lordsin's Avatar
Lord Sin
Lordsin is an unknown quantity at this point
May I ask why is it still obd1 and not obd2 wiring?
Old Aug 19, 2013
Fliptard's Avatar
Fliptard will become famous soon enoughFliptard will become famous soon enough
google search for testing your dizzy and what wires to test for the TDC sensor, you may have a short in your harness or your ecu.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
juicetayne
Sep 30, 2015 11:02 AM
Nalmonte
Sep 28, 2015 01:10 PM
ttamrekab
Sep 28, 2015 01:22 AM
Bruce2
Sep 27, 2015 08:45 PM
