QUICK!!!! Timing belt issue.
Re: QUICK!!!! Timing belt issue.
Go to autozone (or similar) and rent a Honda/Acura crank pulley holding tool. Or buy one for $50 like I did.
Or a chain wrench. That works too
OK...got some serious issues.
Remember....I bought this as a race ready car that was built and had been through several owners......
got the balancer off in pieces. Got the head off and saw no visible damage. top[ of #1 cyl. was clean compared to 2, 3, and 4. No water in the cly.
Block is....D15B7
head marked....P08-1 with cam gear marked 1.6
new head marked...P23-4
I am so messed up!!!! I know ZIP about a Honda...thses numbers mean nothing to me. I have read enough posts the there are a bunch in interchangeable parts AND adjustments MUST be made to prvent catastrophic issues.
I am so MINDF&%KED right now!!!
Block is....D15B7
p08-1 is from a JDM D15B OR a US D16Z6, which is a vtec head. Someone did a mini me buy your info.
The numbers P23-4 looks to be a D16Y8 head, also vtec.
You should be able to bolt the new head on, but make sure you have the cam gear for a D16y8 or your timing will be off.
A y8 cam in all 96-00 EX models
mattdoc
Mar 14, 2017 12:10 PM
Supramk3
May 11, 2015 07:55 PM
Blaster30
Apr 22, 2015 12:21 PM
