1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
O2 Sensor removal problems 94 civic...
Old 02-27-2013
Hfactor's Avatar
Hfactor is an unknown quantity at this point
So I took my car into the shop to get a code check.. asked them to see if i needed a tune up as well.. They charged me 2 hours of labor for them to look... to LOOK at my car. $180 and they did 0 work except check to see if I needed a tune up... ROBBERY Anyways
They told me what I already knew, o2 sensor is returning an error. They said $200 to change it... I bought the part for $30, they said it cost $100. Never going to that shop again.
Anyways I got to working on my car. Bought the new sensor and removed the heat shield infront of the o2 sensor. I got an O2 sensor socket that slips over the wire but the socket must of been spread because no matter what I did it would just slip off the bolt.
Finally cut the wire off the sensor and used a hammer and chisel to smash everything that was infront of the bolt. Now I got a normal 7/8" socket and put a pipe over the ratchet. Applied penetrating oil and lots of heat with map gas. Got the socket on the sensor and reamed it really hard. The bolt snapped off and left a good portion of it in the threads / down in the sensor hole.
Here is an idea of what is still inside the 02 sensor port.
Everything past the red line is still inside the 02 sensor port.
So how the heck do I get the rest out of there?
Do I have to remove the exhaust manifold and do some crazy shenanigans?
Here is what it looks like.
Is it just those 9 bolts holding down the exhaust manifold?
If so I can remove those tomorrow and take a look at whats going on. But I wanted to see if I could get some more ideas about what to do. Also I'm guessing the manifold gasket is going to be bad.... but those are cheap and I can replace it no problem...
I just need some insight on what to do about this broken o2 sensor...
Hfactor is offline
Old 02-27-2013
Lord Sin
Lordsin's Avatar
Lordsin is an unknown quantity at this point
Re: O2 Sensor removal problems 94 civic...
Man your screwed just buy a new/used exhaust manifold. Junkyard or Craigslist is cheapest option. Who ever put the o2 sensor in probably used to much force tightening it.
Lordsin is offline
Old 02-27-2013
They seize and trash threads occasionally. It happens.
One of the hazards of trying to take apart old stuff.
You could remove the manifold and then work with it on a workbench instead of trying to work with it in the car. Or take it to any machine shop to have the pieces removed. Might be cheaper than getting another one.
ezone is offline
Old 03-01-2013
Lord Sin
Lordsin's Avatar
Depending where he is but here I seen them go for 10-30 dollars and a t3/t4 log turbo manifolds for 40-60$. A shop is probably gonna charge him more for labor.
Lordsin is offline
CarStuff
12-06-2020 12:52 PM
mohawkboom
67
08-25-2015 12:28 AM
MN-02-CivicEx
28
05-02-2015 09:11 PM
Civic4ever1996
04-16-2015 08:30 PM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: O2 Sensor removal problems 94 civic...
