1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
B18B swap help
Old Aug 15, 2012
McLellan.MW's Avatar
McLellan.MW is an unknown quantity at this point
B18B swap help
Hey guys I got a few questions regarding a B18B out of a 94 Teggy that will be going into an EG. My plans with the motor is to first rebuild and clean it up:
-eagle rods w/ low compression turbo pistons
-using stock crank and pulley
-full super tech valve train
-stage 2 cam shafts w/ adj gears
-EBay turbo kit
So that's what I plan on doing with the motor as far as a build. The question I'm wondering is will the stock harness off the b18 plug into the civic ports? The Teggy axles will work on the civic? As far as mounts go and linkage I only need to keep the bracket from a civic to use??
If something needs to be done with the harness would someone be able msg me or pm me with details if you've done this or have knowledge
Thanks for the help
Email is roll4life_sk8er@hotmail.com
Have a few other questions but they can wait
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
