help identify 'heater inlet hose' for installing coolant flush Tee?
Rep Power: 0 help identify 'heater inlet hose' for installing coolant flush Tee?
Okay the picture on the back of this kit looks nothing like what's under the hood of my 95 civic ex coupe (MT). Am trying to do a coolant flush to get the rest of the crap out of the engine block after radiator rusted through and leaked, but I am not certain which of these is the "heater inlet hose" as termed on the instructions of the flush kit.:
"Two heater hoses extend from the fire wall to the engine ..Hose #1 runs fire wall to water pump, Hose#2 runs from fire wall to top of engine. This is the heater inlet hose."
Both of the hoses I see appear to go to the side and neither seems to go to the pump or to the the top so I'd like to confirm that I've got the right one before I go and make a mess. Here's the diagram from the service manual that colored for ease of reference - the red and blue the heater hoses and the yellow is the lower radiator hose which goes to the thermostat housing along with the red hose labeled "A". The blue "B" hose connects to ?? (is this a pipe that leads to water pump??):
http://img843.imageshack.us/img843/209/capture.JPG
Sooo- Is it correct to call the red "A" hose to the thermostat the one they refer to as #2 and as the inlet hose at the top of the engine? and the blue hose "B" as their "hose #1 runs fire wall to water pump"?
The kit directions say to install the Tee into a "straight portion of the inlet hose, away from hot exhaust system" which I take to mean I should put in on the smaller red hose "A" somewhere between the firewall and the thermostat housing.
Is this correct?
Thanks for any help on this...
Is this correct?
Rep Power: 0 Re: help identify 'heater inlet hose' for installing coolant flush Tee?
Thank you!
(and btw, the link in your sig is dead... Or rather the link is live, but it's only an index of links that are all dead. So it isn't that useful to link to ... )
7thgensurvivor
38
08-29-2015 11:50 AM
lilrob1213
37
06-29-2015 06:45 PM
mrohitredd
05-28-2015 10:03 AM
