1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
help figuring out civic
Old Jan 31, 2012
freestyle423's Avatar
freestyle423 is an unknown quantity at this point
Unhappy help figuring out civic
heres the story.. obtained a 91 civic lx with hole in block. then obtained another identical car only wrecked front end with a d15b vtech engine that ran. so swapped the engine realized what a crappy job the previous engine swap was. so i had to buy a distributor, intake manifold, bought a p28 ecu with obd0-obd1 jumper harness. ran wires for the distributor and injectors.. now it will not start and my volt meter is reading 23-24 volts to the injectors. how would that be?!!? im stumped... any suggestions?
Old Jan 31, 2012
fishdip's Avatar
fishdip is an unknown quantity at this point
Re: help figuring out civic
Will it even try to start. Or is it nothing when you turn the key?
Old Jan 31, 2012
it turns over and i am getting spark.
Old Jan 31, 2012
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
Fuel pump? Does it prime when you turn the key on. You should hear it for about 2 seconds or so. Fuel?
Old Jan 31, 2012
yes fuel pump is comming on have fuel in fuel rail on intake.
Old Jan 31, 2012
fishdip's Avatar
How long did you try to start it? Best thing to do is scan it and see if you get a code.
Old Feb 1, 2012
Do you have a Chilton's manual? There is a thread on here where you can get a manual, just search for it. What about fuel pressure? just because the rail has fuel, doesn't mean it's enough pressure. I would look at that...
LionSpratt
Jan 29, 2017 11:07 PM
rcolosi
Apr 29, 2015 07:48 PM
Tybonater
Apr 24, 2015 07:03 PM
dooner24
Apr 14, 2015 07:51 PM
locozoko
Nov 4, 2001 05:45 PM
