1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
95 D16Z6 EX COUPE Turbo Set UP
Old Feb 9, 2011
damageduluth218's Avatar
"Boost" its a way of life...
damageduluth218 is an unknown quantity at this point
im looking to build a reasonably priced turbo set up perferably a t3 garret turbo. i want to build the motor and build my own turbo setup. what parts should i get and what brands for my internals and externals. if so could you list everything? thanks it will help a lot! parts iv been looking into so far is comp cam, garret t3 turbo, greddy type s bov, wisico pistons and eagle rods.
Old Apr 10, 2013
Erox630's Avatar
Erox630 is an unknown quantity at this point
Re: 95 D16Z6 EX COUPE Turbo Set UP
I wish someone would have replied im looking for the same things lol
Old Apr 13, 2013
Lordsin's Avatar
Lord Sin
Lordsin is an unknown quantity at this point
What kind of power gain are you desiring for? I am doing a d16y7 turbo build and I'm Doing a JDM sports turbo with mix parts. Going for 5-8 psi. But if you want to go more PSI I would suggest Vitara pistons and Eagle rods with arp studs for internals
Old Apr 30, 2013
KyleSJ6033's Avatar
KyleSJ6033 is an unknown quantity at this point
Exclamation Re: 95 D16Z6 EX COUPE Turbo Set UP
I personally have a d16y7 turbo. I can answer any questions you have. I can tell you the hardest parts for me to come by and anyother problems you might run into. The first thing tho that I would suggest is to get rid of the y7 intake. Your car will thank you with an added 6-8 hp from that alone. The stock d16y7 actually loses horsepower in the middle of the rpm range due to the restrictive y7 intake. Just get you a stock d16y8 intake and use all of it except the injectors and map sensor. I put that on my car and it was a whole other beast. I meant before the turbo also. The injectors in the d16y7 will only hold about 2-3 psi before maxing out while the d16y8 injectors will hold about 3-5 since they are already 240cc. Upgrade to a 320cc injectors and they max out around 8-9 psi. Now when I am talking about the 8-9psi I dont mean fuel pressure. I mean psi of boost. Around 8-9 psi of boost the d16y7 will produce over 200 hp to the wheel.
If you need any information you can either email me or message me and I will try to get back with you in a timely fashion. I have my complete build in my profile tho.
But your car will hold together until around 12 psi on stock internals but I dont got enough ***** to test the theory so mine is set at 9psi. I do however have h beam rods that will support 600 hp but my pistons are not adequate enough yet, nor the valve train, or the head bolts so Im rocking what I got because the final step costs so much money but if I was to put that all together my next dyno run will be over 400 according to my tuner.
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Tommy Cohen
Jun 14, 2015 10:36 PM
Supramk3
Jun 11, 2015 11:13 AM
cmart1209
May 29, 2015 04:52 AM
jdawgzcivic
May 20, 2015 08:14 PM
