1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
No fuel or spark
Old Oct 4, 2010
H3RKID's Avatar
H3RKID is an unknown quantity at this point
Exclamation No fuel or spark
ok so i wanted to build my first car....thinking it would be hard but not this much of a pain in the ***...so i bought a 94 civic ex (eg) shell....then i bought a d15b2..and i changed the dizzy and changed it from dpfi to mpfi ...then bought a obd1 engine harness...installed a d16y8 hydro tranny ...got a free p75 ecu (integra ecu) pieced it all together...fuel pump doesnt work and theres no spark....main relay checks ok...ecu checks ok...all fuses are good....could this be a ecu compatabilty issue? if it is what ecu should i use? take note that i said its an older d15b2 in a newer 94 civic ex. 94 civic ex's came stock d16z6...i have no money for another swap i need to make this work or else i have to junk the whole car and lose all my moneys worth someone please help me!!!
Old Oct 4, 2010
02civicsi02's Avatar
Low and slow!
Re: No fuel or spark
For one why did you put the ef motor in a eg. And second for the d15b2 you need that ecu not from a integra.
Old Oct 5, 2010
H3RKID's Avatar
bcuz it was the only motor i found in my budget bro ..this is a recession lmao i wanna do an ls swap as soon as i get the money for it but to make money i need this motor to run so i can get to work.....and i know an integra ecu isnt suppose to work but i tryed a p28 and stilll.....sadly ...nothing.....so do i need to get an ecu out of an ef and get a step up ecu harness from obdo to obd1?
Old Oct 5, 2010
Low and slow!
Hell all d series motors are dirt cheap. You can get them for like 200$. And you need the ecu that works with the d15b2.
Old Oct 5, 2010
H3RKID's Avatar
yeaa i know they are but i couldnt find any lol ok so ur saying to get an ecu from and ef and get a conversion kit for the ecu to connect to my car and my problem should be solved?
Old Oct 5, 2010
Low and slow!
It should unless there is something wrong with the fuel pump or the spark plugs/wires, coil.
Old Oct 5, 2010
H3RKID's Avatar
thnx bro really appreciate the help....will keep up to date on this forum in case it does not fix my problem
Old Oct 5, 2010
H3RKID's Avatar
if anyone else has any input on a solution please feel free to tell me ur suggestion just in case thius does not solve my problem thank you
Old Oct 5, 2010
H3RKID's Avatar
problem solved!!!! it was the thrmostat ground...car runs good even with the p75 xD thnx guyz
Old Oct 5, 2010
Low and slow!
Wow the one thing most people forget to hook back up that can cause alot of problems. Still weird that it runs off that ecu.
Old Oct 6, 2010
H3RKID's Avatar
yea i know but it revs at 4 rpms...i think it may bcuz i started it without a muffler and i was running open headers
SimpleUser
Apr 24, 2021 02:54 AM
Green02civic
Jul 27, 2015 10:48 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
mistermenphis22
Jul 13, 2015 04:43 PM
