1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
95 Civic EX
Old Dec 26, 2009
emedina's Avatar
emedina is an unknown quantity at this point
95 Civic EX
Hi, i recently purchased my eg and it has a d16z6, everything was fine with the car until the crank pulley bolt magically broke, im still having trouble getting it out but ive done research on that so im still working on it, but my question is where can i find a replacement crank pulley for it and is it a matter of simply replacing the belts with new ones and sticking in the new pulley or might my timing gotten messed up. keep in mind i drove the car from the moment it started rattling to the moment i got home to check what it was so about 10miles. also, are pulleys the same for automatic and manual? any help would be great i live in southern california so im sure there has to be some specialty stores where i can find this damn pulley.
p.s. are the ebay underdrive pulleys reliable? the price is very enticing but i dont want to mess up the engine just for going cheap.
Old Jan 8, 2010
9scex4's Avatar
9scex4 is an unknown quantity at this point
Re: 95 Civic EX
first off, if it was just your crank pulley it would not have effected timing in any way. you are safe there. second i would be careful with "ebay special" underdrive pulleys, it is hard to find reliable aftermarket parts on ebay. i would stick with oem replacement parts if you are looking for dependability. once you get that broken bolt out of the crank, it should be as simple as puting a new pulley and bolt on. if the belts were damaged then replace them also. you should be good after that. i hope i helped...
jonavin
73
Oct 4, 2004 07:18 PM
locozoko
Apr 6, 2002 09:00 PM
silvervtec01
Nov 4, 2001 06:56 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
