1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
7 symptoms, one problem?
Old Nov 9, 2009
lil_wilde's Avatar
lil_wilde is an unknown quantity at this point
OK, so there are several problems with my car so I figured this time I would post them all in one since they might be related. It’s a 1991 Honda Civic Hatchback, 1.5L automatic.
1- I’m getting code 16 from the ECU.
2- The car sometimes won’t start after I have driven it somewhere, stopped for a few minutes and then tried to go again. If I let it sit for a few minutes it will eventually start.
3- The car doesn’t respond to gas sometimes. I will press the gas pedal but it won’t accelerate right away and then I’ll push harder and it suddenly shoots ahead.
4- I seem to be leaking coolant but I’m not positive because there is no puddle. I replaced the radiator when it cracked and added coolant until it appeared to be full but I didn’t bleed the coolant system. When I drove it overheated so I checked and it needed more coolant. I thought maybe if there was air in there it had come out and I was now able to completely fill it up but then it overheated again so I had to add more coolant. Was there that much air trapped or am I losing coolant somewhere?
5- There is a small engine oil leak from the front driver’s side but I haven’t noticed it as much lately.
6- There is a small amount of smoke that comes from under the manifold cover sometimes.
7- There seems to be a lot of exhaust smoke. It is white and could be I’m only
noticing it because of the cold weather lately but it seems suspicious.
I have recently changed the ignition coil in the distributer and like I said I changed the radiator. I had problems 1 and 2 since I bought the car 4 months ago but the other problems are more recent, since the rad. cracked and I overheated it.
I have the Hayes manual and I’m willing to get my hands dirty if it saves me money but I don’t even know where to start.
Old Nov 11, 2009
JDM_Ricer's Avatar
JDM_Ricer is an unknown quantity at this point
Re: 7 symptoms, one problem?
If your blowing white smoke out the exhaust you have a bad head gasket or a cracked head..
Old Nov 17, 2009
lil_wilde's Avatar
Well, I did a compression test and all the cylinders were the same but "low". Oil looks fine, no bubbles in the rad. Don't think it's a head gasket problem, think it was just a matter of not bleeding the coolant system and there really was THAT much air in there cuz the coolant stays full now.
BUT there is still the problem of the code 16. I know it means fuel injection systme but where to start...
I think Ill post a new thread about the code 16 alone.
Thanks for your help.
sharp66
31
Jun 12, 2022 08:45 AM
mistermenphis22
Apr 3, 2016 08:06 AM
jtdunn4life
Oct 27, 2015 03:33 AM
pincookie1
May 4, 2015 12:22 PM
Blaster30
Apr 22, 2015 12:21 PM
