1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
95 EX Running Rough need help
Old Aug 23, 2009
yung_gun89's Avatar
yung_gun89 is an unknown quantity at this point
Got a 95 EX D16z6... So far ive replaced the spark plugs and wires, cleaned the injectors and fuel rail, and replaced the fuel hose from the filter to the rail... A mouse chewed thru my fuel line and ever since ive been having problems... The car sputters on take off and usually clears up at higher RPM... Most of the time it just feels like it doesnt have enough power to move the car... It'll run fine one day then all the sudden start acting up with back fires and sputters... Every now and then itll thro a code for the Fuel pressure, Pressure Regulator, or Filter... wondering if anyone had some ideas or not?
Old Aug 23, 2009
hilton0315's Avatar
hilton0315 is an unknown quantity at this point
Re: 95 EX Running Rough need help
well if you read my post you will see what happened!!! take out your injectors and on the top of them is a removable filter screen, most likely when the mouse chewed through a piece of hose got lodged in the screens, clean out the screens and you will be fine, as was my problem mine was dirt buildup in my screens, and my car did the exact same thing. good luck.
Old Sep 7, 2009
k.civic.f4i's Avatar
k.civic.f4i is an unknown quantity at this point
i have a 94dx hatch and the same thing is happening to me except it never throws any cel.s and the exhaust puffs white smoke. im not quite sure where to start because ive already replaced the fuel filter, air filter, spark plugs and wires and the radiator with hoses. all the syptoms point to 4 things as far as ive researched either bad o2 sensor,bent valves,blown head gasket or bad fuel pump. good luck man
ps. i also had high nox when i passed smog
Old Sep 7, 2009
shnoogens's Avatar
shnoogens is an unknown quantity at this point
k. i think you have a bad head gasket only other way to tell is if your losing water, also yun gun did you replace the cap and rotor??
Old Sep 8, 2009
that was what i expected. i checked it out today and low and behold, it was.
thanks
Burnout
Jul 15, 2022 10:24 PM
alex_nyc
Jun 16, 2015 01:43 PM
Allecr3
May 22, 2015 01:24 PM
ywgflyer
May 15, 2015 05:05 PM
crowtoo
May 11, 2015 06:50 PM
