1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
'95 Civic burning a LOT of oil
Old Jun 21, 2009
Emiras's Avatar
Emiras is an unknown quantity at this point
I figured i would ask someone before i went crazy and started stripping down my car. I just put in new bearings, valve seals and rings in just a couple of months ago. Now, just recently i noticed a lot of white smoke coming from my car when i would drive it, mainly when i would stop. From what i can see, its getting worse over time, meaning more smoke than before. What could it be? I just put in new rings and there was little to no waer on the cylinder walls, so i put in normal sized rings. Any ideas?
Old Jun 21, 2009
04 Honda Civic's Avatar
Re: '95 Civic burning a LOT of oil
Does the car run crappy? Pull a plug see if your getting oil in the cyclinders.
Old Jun 22, 2009
Emiras's Avatar
Well the car runs well, i have been having this problem though where when it idles it revs up and down by itself, we thought it was the Idle Control Sensor, and replaced it with no help -.- But as for the oil, thats pretty much a given isn't it? theres gonna be oil in the cylinders if its burning oil right?
Old Jun 24, 2009
Emiras's Avatar
Anyone?? Well, the spark plugs were pretty much soaked in oil when i went to do a compression check. came out about 165-150-155-170. I thought maybe it could be the catalytic converter causing the leak, so after destroying the converter i cranked up the car only to still have the problem. The amont of oil im having to buy is unreal!
Old Jul 13, 2009
Monotech's Avatar
Monotech is an unknown quantity at this point
Possible bad valve stems seals or guides. Also a possibility can be your top compression piston rings are lined up to where you get blow by.
Old Jul 16, 2009
codyclarke05's Avatar
codyclarke05 is an unknown quantity at this point
sounds like a head gasket leak, are you losing coolant too?
Old Jul 17, 2009
revr63ed7's Avatar
revr63ed7 is an unknown quantity at this point
Civic head gaskets rarely leak oil into the combustion chambers. They leak oil down the back of the engine from the oil jet that sits in the deck of the block. Did you deglaze the bores when you installed the new rings, and what kind of rings did you use?
Runner88
Mar 2, 2023 04:54 PM
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
usajags84
15
Aug 19, 2015 03:12 AM
tattedlariat
Apr 17, 2015 03:26 AM
