EX rough idle
Rep Power: 0 EX rough idle
The problems continue. I have this issue with my EX idling roughly. Yesterday, I was sitting at a red light and the rpm went down to 0 and shut off. Twice at the same light. So I put it in neutral whenever I was stopped at the engine and revved so I could keep it alive until I got home which was two miles away. I did a little research on it last night and i found some threads on this issue that recommended replacing the throttle body. I wasn't too sure if that was the issue and I don't want to go around changing parts that don't need to be changed. I continue to have a misfire code and I have my suspicions with one of the injectors clogged on the fuel filter but again, they are only suspicions. Anyone have any suggestions or have the same problem? I don't even know if these problems are connected in someway.
Re: EX rough idle
It's not caused by the throttle body.
Compression test?
Re: EX rough idle
Wait wait wait......
Does it still set misfire codes now that this has been done?
What exactly does this "ignition system" entail?
riceburner254
05-09-2013 01:08 PM
boostnm3
Buy, Sell, & Trade - Archive
12-22-2009 10:57 PM
