Coilovers help!
Old Jan 28, 2018
Eknoodle's Avatar
Eknoodle is an unknown quantity at this point
Coilovers help!
Hey I'm new to the civic game. I'm fairly new to the stance game as well. And I know stance is bad and what not but it's what I like. Anyway straight to my current question, I just bought some function and form coilovers from a friend and to go low I need to move the spring seat higher in the rear. I've moved it higher so the spring is some what compressed between the seat and the top hat. I set the car down with my desired wheels and it's not as low as the front. But to go lower I need to move the seat higher so I can adjust the ride height. As of right now the spring seat is touching the ride height seat so I can't go lower. If I compress the spring too much what would happen? If it's bad should I get extended top hats? Are they any good? Please let me know. Thanks for sharing your knowledge ✌🏼
Old Jan 29, 2018
GolNat's Avatar
Prelude Owner
Re: Coilovers help!
You should buy shorter springs. You compress them to much they won’t act like springs anymore.
Check out ground control for custom springs.
Old Jan 29, 2018
Re: Coilovers help!
that's called spring bind - and it's bad
Old Jan 29, 2018
Eknoodle's Avatar
Re: Coilovers help!
Okay what should I be looking for when look for shorter springs?
Old Jan 29, 2018
Eknoodle's Avatar
Re: Coilovers help!
Okay thanks man. I kinda wanna do this right so I don't look like the typical ricer with bouncy set up lol
Old Jan 29, 2018
GolNat's Avatar
Prelude Owner
Re: Coilovers help!
What you have might be as short as you can go. I would talk with Ground Control about it. They might be able to wind you a tighter spring. Also a higher spring rate might help. Combining the higher spring rate with a shorter spring might work. I have no personal experience in this though.
Extended top hats would also help with getting it lower. I have never used them.
EM2 FREak
Oct 31, 2020 08:17 AM
filipinop1405
Mar 2, 2006 07:13 AM
j0nblayz
Jun 30, 2002 10:25 PM
StLVtec
Jun 8, 2002 04:34 PM
HeRbaLuS
May 4, 2002 04:27 PM
