b20v w/ b16a2 head sputtering after 3-4k rpm
Old Dec 8, 2017
fw_walty_ek's Avatar
fw_walty_ek is an unknown quantity at this point
have my 99 civic hatch with a fully built b20v w b16a2 head and was hoping for your guys help! my car just started sputtering out of no where and now no matter what gear can't pass 3-4k rpm without it sputtering and backfiring. fuel pressure seems to be staying where it needs to be so i'm lead to believe spark either wires or plugs possibly distributor too? let me know what you guys think please and thank you!
Old Dec 9, 2017
Wankenstein's Avatar
Re: b20v w/ b16a2 head sputtering after 3-4k rpm
B16A2 appears to be a Vtec head. If that is the case the issue may be related to the Vtec solenoid itself. First, check oil level..low oil can cause Vtec solenoid to improperly operate. Read this: http://my.prostreetonline.com/2014/1...c-doesnt-work/
Other than Vtec solenoid check:
Mechanical timing to ensure timing belt didn't jump tooth/teeth
Valves adjustment
Spark quality.
Compression.
Whatever else Ezone or others recommend.
Out of curiosity which ECU are using and does it have a chipped basemap or tune?
Old Dec 9, 2017
Got fault codes?
Old Dec 9, 2017
Valves adjustment
Spark quality.
Compression.
I have a hondata s300 tuned on e85 with aem e85 pump and aem rail and regulator and filter so I don't know honestly.
Old Dec 9, 2017
Originally Posted by ezone
Got fault codes?
my ecu wasn't reading any no sir!
Old Feb 20, 2018
dcstomp83's Avatar
FrankenCivic
dcstomp83 is an unknown quantity at this point
when you say fully built...i'm assuming that includes the oil line to feed the vtec and the girdle...which head gasket are you using...did you swap over to the b16 water pump and timing belt or did you stick with the b20...are you using the b16 ecu?
this engine is touchy when something is off...but when it's working correctly it's a beast
Z-Honda
Dec 17, 2013 05:28 PM
Yakapo
Jul 28, 2013 09:44 AM
Blue_SI_Boy
Feb 13, 2013 10:53 PM
hlmeans
Sep 12, 2012 01:45 AM
1028CiViC
Jul 31, 2002 05:40 AM
