1998 Civic Stalls
Old Jan 14, 2016
generye's Avatar
generye is an unknown quantity at this point
1998 Civic Stalls
I have a 1998 Civic that will intermittently stall. The vehicle will not re-start for 5 - 10 minutes. I have replace the Main Relay, Distributor, Ignition Control Module, Ignition Coil, and lastly the Key Ignition. I have not replace the Temperature Control Module. Any ideas what else may be wrong?
Old Jan 17, 2016
Miss EJ6's Avatar
BPL Namdata
Miss EJ6 has a spectacular aura aboutMiss EJ6 has a spectacular aura aboutMiss EJ6 has a spectacular aura about
Re: 1998 Civic Stalls
check your map sensor
Old Jan 17, 2016
generye's Avatar
The car is not throwing any codes, check engine light does not come on. If it were the MAP sensor, it should throw a code.
Old Jan 17, 2016
mac25's Avatar
Dr Krieger of Modification
Check fuel pressure.
If ignition system and starter are working then the last item for combustion is fuel.
I had a faulty fuel pump at 150,000km which made my car stall out.
Try this as well, before you start the car prim the fuel lines four times.
Just turn the key two clicks so the dash is on but not the engine, wait 4 seconds, then turn the ignition all the way off. Repeat this three more times, then try starting the car.
If it starts right away you have a fuel pressure issue. If it still stalls you may still have a fuel pressure issue (use a pressure gauge to verify).
Old Jan 18, 2016
WildM80's Avatar
WildM80 is an unknown quantity at this point
generye,
I was having the same issue in my 98 LX for the longest time. It seemed that it would happen more frequently if I was turning or braking hard. It plagued me for a while. I also replaced the distributor, battery, alternator, ground cables, checked and triple checked fuses. I know you wrote that you replaced the key ignition. I was curious if you also meant the entire ignition harness itself? If not try that next, I had a local shop replace mine and not only has it not shut off on me but it seems my car starts easier too. There is also a recall stating that the contacts can degrade thus stalling the engine without warning. Here is the recall and the link. Hope this helps!
NHTSA RECALL NUMBER: 02V-120
MFR CAMPAIGN ID: L55
CAMPAIGN DESCRIPTION: 1997-99 HONDA IGNITION SWITCH
RECALL DATE: 05/13/2002
RECALL STATUS: 17 Character VIN Required
SUMMARY: ON CERTAIN SEDANS, COUPES, HATCHBACKS, AND SPORT UTILITY VEHICLES, ELECTRICAL CONTACTS IN THE IGNITION SWITCH CAN DEGRADE DUE TO THE HIGH ELECTRICAL CURRENT PASSING THROUGH THE SWITCH WHEN THE VEHICLE IS STARTED.
SAFETY RISK: WORN CONTACTS COULD CAUSE THE ENGINE TO STALL WITHOUT WARNING, INCREASING THE RISK OF A CRASH.
REMEDY: DEALERS WILL REPLACE THE IGNITION SWITCH. OWNER NOTIFICATION BEGAN JUNE 14, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HONDA AT 1-800-999-1009 OR ACURA AT 1-800-382-2238.
http://owners.honda.com/service-maintenance/recalls?id=
Wiggles
Sep 8, 2015 05:05 PM
Mannimarco
Sep 7, 2015 10:01 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
Kenjitsu
Aug 28, 2015 04:45 PM
jnissen
Aug 9, 2015 05:34 PM
