B18B1 Swap In EJ8
Old Nov 25, 2015
Gavin_EJ8's Avatar
Gavin_EJ8 is an unknown quantity at this point
B18B1 Swap In EJ8
So I have a question. Couple years back I had a b16a2 swap in my 1998 Honda Civic 2 Door "Si" model. Original Motor was a D16Y8 but later on both motors were toast.
This year I had a friend pass on his integra which was totalled in the rear and I took his motor which was a b18b1 obd2 manual. car starts up with no issues but I received a couple of codes. so after many nights of repairs I have beaten all the codes except one..
Code P1259: Vtec System Malfunction
Now because the b18b1 is a non vtec motor I have removed my obd1 Chipped ECU p28 and installed a OBD2 civic ECU and I have removed the vtec harness completely since it was a add on splicing into the ECU wires. no matter how many times I erase this code it keeps popping up. I've been driving around with my temp since.
Is there anyway to disable the code for good ? Or at least by pass it? Should I get the ECU flashed and do some remapping work? I heard about the oil being apart of this, I know it's not plugged in and that's why the code is there.
Some one help
Old Dec 1, 2015
Miss EJ6's Avatar
BPL Namdata
Miss EJ6 has a spectacular aura aboutMiss EJ6 has a spectacular aura aboutMiss EJ6 has a spectacular aura about
Re: B18B1 Swap In EJ8
you need to use a non vtec ecu
Old Dec 1, 2015
mac25's Avatar
Dr Krieger of Modification
b16a2 = 160hp
b18a1 = 142hp
...I hope you aren't planing to swap the b18 non-vtec for the b16 vtec.
In fact swapping this motor into anything seems odd for all the time/money/pain in the ***, why not find a b18c1 (170hp) or b18c5 (195hp)?
...or wait to swap the engine and while it's out find a c1 or c5 head and ecu.
Old Dec 7, 2015
Miss EJ6's Avatar
BPL Namdata
mac25 he used to have the b16a, which he also stated got toast and got a LS from his friend as a replacement motor
Old Dec 7, 2015
Gavin_EJ8's Avatar
That's correct. I have tried on a non Vtec ecu and I have tried to erase the code but it doesn't work.
Should I have this issue disable instead ?
Old Dec 7, 2015
Miss EJ6's Avatar
BPL Namdata
your still getting vtec malfunction code, even with the non vtec ecu???
Old Dec 7, 2015
Miss EJ6's Avatar
BPL Namdata
thats really odd being that all non vtec ecu has all the vtec component/chips removed from the circuit board. but then again some non vtec ecu can be converted to a vtec ecu. if all else fails you can always have the vtec disabled.
muttleytm
Jul 14, 2015 05:31 PM
671civicLX
Jul 9, 2015 03:22 PM
old97civic
Jul 9, 2015 12:19 PM
civicPesek
Nov 7, 2001 11:33 PM
