Broken Cylinder Bolt :(
Old Sep 20, 2015
amrhamed's Avatar
amrhamed is an unknown quantity at this point
Angry Broken Cylinder Bolt :(
Hello Everyone , today i was changing my head gasket for Honda Civic 2000 unfortunately i snapped 2 bolts beside each other what should i do now , should i drill it or what i am really confused
Thanks for Help
Old Sep 20, 2015
Mad Dog Tannen's Avatar
Re: Broken Cylinder Bolt :(
Thanks for Help
pics?
Old Sep 20, 2015
Yeah, lots of bolts there. Which ones, specifically?
Old Sep 20, 2015
amrhamed's Avatar
the right one from the bottom & the middle one from the bottom
Old Sep 21, 2015
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
how did you snap two? why didn't you stop after the first one broke?
how tight did you get them? If you start taking stuff back apart can you a get a big pair of vice grips on it and back it out that way?
Old Sep 21, 2015
mikey1's Avatar
this is a very good question
Old Sep 21, 2015
amrhamed's Avatar
I can't use vice grip because the there are no appearing bolts to hold it back , i broke 2 because i was thinking that the way to unscrew them is clockwise not counter clockwise any way no body learned for free
Old Sep 21, 2015
I am really not trying to be insulting here, but if you don't know which way to turn the bolt, you should not be doing a head gasket replacement by yourself. You also broke 2 bolts off because you where either over tightening them or you where turning them the wrong way. If anyone told you this is a beginner job, they where lying.
If you don't have a service manual, then get one. If you don't have a torque wrench, get one. Assume all bolts unscrew counterclockwise unless otherwise stated in your manual.
Send pics, it's difficult to imagine what is happening from your written description.
I hope that helps a bit.
Old Sep 21, 2015
amrhamed's Avatar
I know its my bad , i gonna take some pics and send to you
Old Sep 21, 2015
mikey1's Avatar
wow.....either i smell a troll.....or its a major +
after you broke the first one and thought you turned it the wrong way, why wouldn't you try the other way on the second one?
Old Sep 21, 2015
amrhamed's Avatar
Its not leaking anyway because i put some silicon on the broken bolts
Old Sep 21, 2015
mikey1's Avatar
i think my first guess was correct
Old Sep 21, 2015
Old Sep 21, 2015
Yeah maybe, that doesn't even sound like it would work. But then again I have never tried it before lol.
Old Sep 21, 2015
I'm glad I'm not the only one that still has no clue as to which bolt OP is referring.
edit: just hit me. How did you snap a bolt in the engine. You're much more likely to strip out the threaded hole than you would be to snap a fastener.
glockma630
Aug 1, 2015 10:30 AM
Bounddyy
19
Jul 20, 2015 02:42 PM
EliseKStewart
Jul 15, 2015 11:11 AM
muttleytm
Jul 14, 2015 05:31 PM
ballmich
Jul 9, 2015 11:59 AM
