D16Y8 idle
Old Apr 28, 2014
Hayden_Fourroux's Avatar
Hayden_Fourroux is an unknown quantity at this point
D16Y8 idle
I have a D16y8 and when it warms up it studders and then almost stalls. I recently did a tune up, spark plugs, fuel filter and new air filter, and i cleaned the throttle body really good. But the problem is still present. Timing in good idle speed os exactly where it needs to be. Has anyone else had this probelm and what else can i check?
Old Apr 28, 2014
Re: D16Y8 idle
Does it run badly when it does this, or is just it a matter of idling too slowly?
Clean the IAC/clean throttle body/set min air rate/relearn idle
Old Apr 28, 2014
Re: D16Y8 idle
No it will run fine then it will studder, run fine then studder. The pattern continues until the engine cools down. But I'll give that a try and see what happens
pfwel1977
Sep 10, 2015 02:16 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
msaeger
Sep 2, 2015 08:47 AM
Dani1993
Jul 24, 2015 09:02 AM
