weird smell and little bit of smoke
Old Jan 9, 2014
tishawn23's Avatar
tishawn23 is an unknown quantity at this point
i recently changed my oil and i got the right oil and oil filter and did everything right to change it but after that for a couple of days off and on there would be a little bit of smoke coming from somewhere underneath the hood but i cant tell from exactly where. Also if i turn the heat on i can smell it being drawn in. Is it just coincidence that its happening at the same time? What could it be thats smoking and why?
Old Jan 9, 2014
Re: weird smell and little bit of smoke
The usual 'oil change related' cause would be oil on the exhaust, and burning off when the pipe gets hot. The filter is right over the exhaust pipe, and the back of the engine can hold quite a bit of oil to dribble as you drive.
Look under the car, see how much oil got dribbled onto the exhaust pipes. See if the pipe is still wet with oil.
Make sure the engine is still full of oil too, make sure it isn't a real leak.
HTH
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
alaga
25
Aug 13, 2015 04:42 PM
DerbyDad03
Jul 27, 2015 11:34 AM
BootyDo
Jul 26, 2015 10:38 AM
1khilari
Jul 9, 2015 08:12 PM
