98 civic ex idle air control system
Old Nov 14, 2013
rujoesmith's Avatar
rujoesmith is an unknown quantity at this point
I recently replaced the cylinder head on my d16y8 with a re manufactured head. About 15 minutes after driving it, the check engine light came on with code P0505 "Idle air control system".
It idles at 1700rpm and every time I lightly press the gas pedal the engine starts sputtering to the point of nearly stalling. But for some reason this doesnt happen at all if I give it a good amount of gas. For example, when im at a stop light and i just try to move a little forward it starts lurching just like the first time i learned to drive stick. But once i get going i have no problems at all.
I thought it may be a timing problem, but when i went to adjust it i found that no matter what i do it continues to idle at 1700rpm and the timing readjusts itself after about 30 seconds so that it is never where its supposed to be. And yes i did short out the 2 pin connector by the ecu before adjusting the timing.
Even though i replaced the head myself my knowledge is pretty much limited to the step by step instructions of a manual. So if anyone has an idea of what might be wrong it would be greatly appreciated.
Thanks!
Old Nov 14, 2013
Fliptard's Avatar
Fliptard will become famous soon enoughFliptard will become famous soon enough
Re: 98 civic ex idle air control system
to adjust the ignition timing via Distributor, you need to jump the 2 prong connector by the ECU. just jump it with a paper clip and them move the Dizzy.
Did you make sure the mechanical timing is dead on?
And re-bleed your coolant system, before that tho, unbolt your IACV and spray it out with break cleaner, re-bolt it then bleed the crap outa the coolant system.
Old Nov 14, 2013
rujoesmith's Avatar
Ya I jumped the 2 pin connector which is why I though it was weird that it kept readjusting itself every 30 seconds or so. It's almost like movinng the dizzy has no effect. And ya I'm 100% sure the mechanical timing is dead on. I'll try the cleaning/bleeding and see how that goes next, thanks for the input
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Pir8pete
165
Mar 6, 2009 05:16 PM
Microbiology
Nov 9, 2001 10:10 PM
