Axleback muffler gasket
Old Sep 29, 2013
WaryDriver's Avatar
WaryDriver is an unknown quantity at this point
I am getting the Walker 53162 muffler. My current gasket is destroyed, cannot reuse.
Should I order a Walker 31614 gasket or Honda Genuine 18229-SNE-A01 (previously 18229-S01-X01) gasket?
Civic 1998 DX 3door Hatchback D16Y7
Old Sep 30, 2013
WaryDriver's Avatar
Re: Axleback muffler gasket
I forgot to mention. The pipe that will be leading to the muffler has never been replaced therefore original Honda. So I will have original old honda pipes leading to this new Walker muffler. What gasket should I choose, the Walker gasket or Honda Genuine gasket?
What does the gasket matter for? The pipe leading to muffler, or does it matter to the muffler?
'98 DX 3door Hatchback D16Y7
Old Oct 15, 2013
swoody's Avatar
Duct Tape Technician
swoody is an unknown quantity at this point
You should be fine using a non-Honda part here. These should all be OEM replacement parts, and I don't foresee any issues getting them to fit.
I wound up just purchasing the Bosal axle-back muffler, and a new gasket to go with it. I will be doing the actual replacement this next weekend, so I haven't taken it apart yet. I also picked up a couple replacement bolts as the original ones on the car may need to be cut to remove them. I have been dousing them with PB Blaster, but that may not be enough.
However, from what I gather the gasket is actually a packed metal mesh piece which interfaces between the two exhaust pipe ends. It just prevents leaks and rattling between them.
You can see the full layout for your model here:
http://www.qcsonline.net/bosalb2b/pr...s/03809302.gif
SimpleUser
Apr 24, 2021 02:54 AM
cukaracha
Aug 27, 2015 02:02 AM
Nalmonte
Bolt-on Engine Performance
Aug 12, 2015 08:38 AM
Nalmonte
Aug 1, 2015 07:57 AM
CivicsClass101
Jul 9, 2015 11:14 AM
