Oil Burning (nOOb)
Old May 10, 2013
Hayden_Fourroux's Avatar
Hayden_Fourroux is an unknown quantity at this point
Oil Burning (nOOb)
I've been noticing in my '97 Ex, that when i accelerate hard, my engine is burning oil. HUGE noob, any suggestions on what could be causing it???
Old May 10, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: Oil Burning (nOOb)
Impossible to diagnose over the internet. Is it VTEC? Could be the vtec causing it, could be piston rings.. who knows
Old May 11, 2013
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Ericthecarguy recently said this about a similar problem on a 1997 HX Civic on his Facebook; "The give away is that you see blue smoke under acceleration, this says rings. Cylinder pressures are higher at this time so if your rings are weak this is where it will show up. If it were valve seals you'd see more blue smoke at idle because of the higher intake vacuum. www dot youtube.com/watch?v=KWjF56tFzRg"
brags
46
Jan 7, 2016 09:39 PM
wootah88
Jul 21, 2015 10:22 AM
1khilari
Jul 9, 2015 08:12 PM
