Mini-Me Swap within the next couple of weeks
Old Apr 1, 2013
burgoyne's Avatar
burgoyne is an unknown quantity at this point
I am starting a different thread, please close this if a mod comes across it.
Thanks
Old Apr 2, 2013
Lordsin's Avatar
Lord Sin
Lordsin is an unknown quantity at this point
Re: Mini-Me Swap within the next couple of weeks
Depending on your mechanical skills it takes 2 hr or so there is a step by step just google the guy who did it put step by step pictures. Have you ever driven an ex civic? It is noticeable but not by much like swapping into a B series engine.
Old Apr 2, 2013
burgoyne's Avatar
I have never driven an EX, just my LX, and a newer LX as well. I will look into that step-by-step, thanks!
Old Apr 2, 2013
Lordsin's Avatar
Lord Sin
I don't see that much of a noticeable Increas I had an ex 2 door and sold it for a 90 hatchback. I will however do a turbo set up on my D16Y7 for a noticeable difference
Old May 13, 2013
burgoyne's Avatar
Alright, so I've done quite a bit of research on this, and am about 80% ready to this lol.
I just need someone to clarify ECU's for me, i'm not exactly electrically savvy lol. I hear I need a P28 ECU with an OBD2 to OBD1 harness. Is this correct?
I'm looking online for P28 ECU's, and I keep finding chipped ones that make the check engine light as a shift light, and deleting the knock sensor, and what not. I do not want this. I just want a plug and play v-tec ECU that will work like a stock v-tec. Where have you guys gotten ECU's to use with your mini-me swaps?
Old May 13, 2013
burgoyne's Avatar
I am going to be going to the junk yard and finding a Y8 head, and taking the manifold too. Can I just take the ECU with me as well? Will that work?
I am guessing I need to take the throttle body as well?
Old May 14, 2013
Lordsin's Avatar
Lord Sin
Yes the Y8 vtech is obd2 while the Z6 vtech is obd1. You can get it all from the junk yard. I'm a N-Vtech person. But if you do get a head from the junk yard please don't be cheap and do all the valves, retainers, and seals. A complete head overhaul so you know nothing is wrong with the head/parts. I say this because a friend replaced a head and did not listen to me and it had a bent valve.
Jigee
May 9, 2015 11:18 AM
dragonsblood
Apr 27, 2015 12:28 PM
Blaster30
Apr 22, 2015 12:21 PM
DaPipeLayer
Nov 13, 2001 08:48 AM
Grazzhopper
Nov 11, 2001 08:06 AM
