Could I killed my engine with what I did?
Old Mar 12, 2013
rovafa2002's Avatar
rovafa2002 is an unknown quantity at this point
Hi Everybody,
I recently bought a 99 Civic EX with 128000 miles on it. Some weeks ago I decided to check the timming on my car. Reading the Hayness I bought for it I saw the factory setting should be BTC12 +- 2.
I decided to go for 14 since it would be a bit better on fuel economy. The problem is that I set my timming light to 14 degrees and I aimed into the 14 degree mark on the pulley. For what I understand this is bad since I put a total of 28 degrees on it? My previous car only had a mark so that was easy but I got confused with this one.
The thing is that I was hearing some knocking (not any pinging) on it and started doubtinhg whether my rod bearing were fried, then I set it correctly puting the gun to 0 degrees and aiming to the 14 mark in the pulley and this knock went away, but I still hear a bit of bearing noise.
My question is if there is a chance of having any other issues appart from that?. Maybe this bearing noise is normal and it was on it all the time. I only ran the car for something like 500 miles and very quietly, I think only one time hitted the 7000 k rpm range. Another thing that worries me is that my knock sensor is bad but anyways I did not hear any pinging on the car at any time.
Thanks!
Old Mar 12, 2013
Re: Could I killed my engine with what I did?
I can't hear it from here, LOL
If you have a bearing issue that is serious, they usually deteriorate rather rapidly until it sounds like a gremlin with a sledgehammer inside the engine....
Most of those engines develop main bearing rattle as they age anyway, not a big deal but it can be noticeable at times.
If you really have a bad bearing problem, you will end up replacing the engine at significant expense.
If you don't have a real problem, the engine will continue to live as-is without getting worse rapidly.
I'd keep the oil full, keep driving it, and see what happens down the road.
wankers
Jan 20, 2019 06:44 PM
MiniMi
May 27, 2015 01:57 PM
paddystrang
May 18, 2015 09:56 PM
