97 Civic power window ??
Old Mar 7, 2013
bad71chevy's Avatar
bad71chevy is an unknown quantity at this point
I just bought this 97 civic 2 door. The drivers window works fine but my problem is with the passenger window. It will go up but not down. There are two wires going to the window motor. One is blue/ white trace, and one is blue/ red trace. The blue/white has power when switch is pressed down. blue/red has power when switch is pressed up. If i put a ground wire on the blue/red then it rolls down fine, but it will blow the fuse when you roll it up. If i unhook the ground it will roll up fine without blowing the fuse. Any ideas???
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
mdd5
Apr 21, 2015 06:54 PM
SSMatey
Apr 13, 2015 06:09 PM
mj1010
Aug 26, 2001 09:52 PM
