97 civic power window problems
Old Mar 5, 2013
JNVA17's Avatar
JNVA17 is an unknown quantity at this point
So I've been dealing with this for a while. I was swapping my doors(car accident) and I broke some wires in the floor harness driver side(comes out the fender plugs to door wiring harness) passenger window would not roll down. Tried to find the harness or end piece but no luck. So I decided to wire the floor harness and door harness direct did not work. Just mirrors worked. Now my sunroof doesn't work. The switch clicks but nothing.The fuse is fine for sunroof. Just unplugged the harness I tried to connect. Still nothing Two questions
1) has anyone successfully wired to floor harness to door harness with full power locks windows mirrors tweeters etc
2) are there relays for the su roof bc the fuse an switch seem to b ok
Old Mar 5, 2013
truefriend's Avatar
truefriend is an unknown quantity at this point
Re: 97 civic power window problems
is their action from the other switch? then it;s not the motor ;; you may not pushed the harnesss togeather all the way,,, or not have alined the pins correctly ,do you know how to check for power with a test light , have someone work the switch while you do the test light , I take it you all ready checked the fuses? relays...because the door came off another car make sure the pins are the same count and the wires colors match if the doors are the same year your replacing, all else fails run 12 volts straight to these parts,or their switches,,their is a common ,a up pin and a down pin or [open /close]
Old Mar 8, 2013
JNVA17's Avatar
Idk I had to cut the plugs off from the floor harness and door harness and splice te wires together. I did check fuses but not the relays. Could my wiring job have blown a relay? The spliced wires are currently disconnected as I couldn't get anything but the mirrors to function properly
Old Mar 8, 2013
JNVA17's Avatar
And if u are talking about the passenger side switches no. No power. Everything worked except passenger window rolling down an power locks until I cut the plug that is
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
mdd5
Apr 21, 2015 06:54 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
mj1010
Aug 26, 2001 09:52 PM
