h22a1 or b16b
Old Jan 10, 2013
98Honda4banger's Avatar
98Honda4banger is an unknown quantity at this point
h22a1 or b16b
I'm going to swap my engine on my 1998 dx coupe, it already has the d16y8 swap in it. I'm unsure of which engine to swap to. I'm planning on rebuilding it and refurbishing it to handle a turbo as well. Would it be better to go with the bigger h22 or just stick the the 2 litre type r engine? Or should i just rebuild the internals on my d16 and turbo that? THanks for any input.
Old Jan 11, 2013
marek91's Avatar
marek91 is an unknown quantity at this point
Re: h22a1 or b16b
if you want to boost stay away from an H not a strong motor wont last long.
if you wanna boost IMO D is the strongest, a stock D will hold 7-10 lbs all day which equals to about 250-350 WHP
Old Jan 11, 2013
Re: h22a1 or b16b
Really? the dohc bigger 2.0 b series couldn't handle more than the 1.6 sohc?
Old Jan 11, 2013
marek91's Avatar
Re: h22a1 or b16b
if you want to boost a B then I would go for the LS the sleeves are a little stronger then the B20, both on stock internal will hold about 275 WHP you may get an extra psi or so on the LS safely, and you will save a couple bucks.
Old Jan 11, 2013
Re: h22a1 or b16b
And you think i'd be able to push higher boost on modified internals with the d series??
Old Jan 11, 2013
Re: h22a1 or b16b
if one wants to make an engine light, it will not hold as much pressure.
if you want to make a engine stronger for pressure, it might weigh a lot
Old Jan 14, 2013
marek91's Avatar
Re: h22a1 or b16b
It really comes down to your preference, I do like B16's and B20's. But for running boost I find the D to handle it the best, You can definitely build it to hold 20-30 pounds. . . all depends how big your wallet is.
I mainly like my D's because if i blow one i spend 300 bucks and get another one, take about 3-5 hours to replace and im rolling again.
Old Jan 14, 2013
Re: h22a1 or b16b
Alright thanks for the input, has given me things to think and reconsider about.
Theshwartz35
Jul 18, 2015 10:49 PM
MindBomber
Mar 19, 2011 08:31 PM
BlueEM2
Buy, Sell, & Trade - Archive
15
Dec 8, 2010 07:58 PM
akai
Feb 22, 2004 12:23 PM
Player1
Jun 14, 2003 04:31 AM
