Rattle noise And P0172 code
Old Jul 27, 2012
RudyG619's Avatar
RudyG619 is an unknown quantity at this point
So my car makes a rattling noise when in park,i look under my car and it looks and sounds like the muffler specifically from this place where its connected at.And theres also a little bit of smoke coming out the muffler.Not too much but slightly noticeable.also i keep getting the fuel too rich bank 1 code,and i was wondering what i have to do to fix it?my car did overheat the other day due to a coolant leak but i was driving it no more then 4 miles while it was hot and i put water in before and half way home..and as soon as i got home fixed it and filled it up with antifreeze..nomore overheating but rattling and smoke yes lol..If anyone can help me id really appreciate it.Thanks b4 i
Old Aug 1, 2012
antrmo's Avatar
antrmo is an unknown quantity at this point
Re: Rattle noise And P0172 code
my guess would be the rattle is a cooked and broken up cat, that would also explain the rich code, cause your cat is not doin its job.possible the coolant leak was a head gasket leak? cause misfire? over heated cat and melted?...bang on the cat with a rubber mallet and see if it rattles? go from there. cheers.
Old Aug 3, 2012
RudyG619's Avatar
What do you mean by the cat?I'm thinking catalyctic converter?? And is that bad do I need to fix it asap or can I run my car like that?
Old Aug 4, 2012
antrmo's Avatar
yes i mean the catalitic, and its not good to run it if its broken up.if there is a coolant leak you should fix that aswell,or the new cat could end up the same,see raw fuel will gather in the cat if its not being burned in the engine, then it will burn in the cat and over heat it and melt it. so make sure you fix both, assuming there is a miss fire of course.,did you check the cat yet? were was the coolant leak anyway?
Old Aug 6, 2012
RudyG619's Avatar
Well I hit the catalyctic converter with a rubber mallet and it wasn't rattling,but I hit a piece closer to the end of the muffler and it sounded like something was in there rattling a bit..you see the car doesn't always rattle just sometimes..and the coolant leak was from a hose I think it was going to ac or something but we fixed that right away..
Old Aug 7, 2012
antrmo's Avatar
well sounds like the baffle in your muffler, has broken.. take off your muffler and shake the muffler, that will tell ya.coolant lines dont connect to a.c lines ,but glad you fixed it.
Old Aug 8, 2012
RudyG619's Avatar
Yeah you think if I put a new muffler that will fix it??another thing too yesterday I was driving first time I drove kinda far inna while and I kept feeling some kind of heat coming from the arm rest like where the emergency brake is and my gas seems to be going by quicker but I'm guessing that's from the p0172 code..thanks for your advice man,appreciate it..
Old Sep 7, 2012
antrmo's Avatar
heat from armrest area, i belive under car in that area is the cat? have a look. if your cat is plugged or broken inside,, i.e the rattle noise,it will get hot and melt inside if gets hot enough, i still think the cat needs replacment but muffler could be pooched to,, maybe u have 2 issues?
Old Sep 7, 2012
B15Fred's Avatar
B15Fred can only hope to improve
what he said ^^
Old Sep 10, 2012
RudyG619's Avatar
Yeah I put a new muffler on it and it hasn't rattled anymore..and the heat I still feel it rarely but I just had a smog check done so who knows what it is lol..thanks for the reply tho ..
DVexile
Jul 2, 2021 05:25 PM
juror
Jun 9, 2015 02:15 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
Shawn02
Feb 12, 2002 08:55 AM
silentbutviolent
Jan 7, 2002 07:35 PM
