Squeaking in Front end
Old Feb 6, 2012
jb13's Avatar
jb13 is an unknown quantity at this point
I have a 96 civic the front end squeaks like crazy. I changed the control arm because of the upper ball joint. It fixed it and it stopped for a few hours and then started squeaking again. It happens when you turn the wheel and if you push on the fender. Any clue of what it could be?
Old Feb 10, 2012
toucansam333's Avatar
toucansam333 is an unknown quantity at this point
Re: Squeaking in Front end
Your springs on the struts are likely binding. If they are original they might need an upgrade. If you are just trying to get by for a short while i would not worry about it. If the car is in good shape and you are planning on keeping a couple years i would just go throught the front end and replace everything once. Sucks having to go back in there a few times a year. Go over it all at least and check and then get a front end alignment done.
edspyhill09
Jun 12, 2016 02:45 PM
Lopes101
Jun 7, 2015 08:04 PM
chuffsy
May 15, 2015 12:50 PM
pheaton
May 4, 2015 08:26 PM
GH04si
Apr 15, 2015 08:13 PM
