98 with Manual Transmission.. oil question.
Old Jan 30, 2012
Cbird's Avatar
Cbird is an unknown quantity at this point
Apologies if I missed the answer to this.
daughter just bought a 98 with Manual Trans. I'm going to change the trans oil (along with other fluids). I see that Honda is recommended. Is it the only approved oil (I'm willing to put it in if so), or are there others that will work fine also. Reason I ask, I have a dodge that requires a unique fluid (liquid gold). Is this the same way. And if it's the Dealer fluid, are there online sellers where it is cheaper?
thanks
Old Jan 30, 2012
Stock 99's Avatar
Re: 98 with Manual Transmission.. oil question.
I just did my 99 civic last month. It seems that OEM coolant/trans fluid is the general recommendation for these cars. It takes 2 liters (quarts) and they were $10 each at my local dealership. I didn't really think that was alot of money for 2 years/50000kms. Transmission bearing issues have been noted for Hondas '92-'05. So if you do use something else make sure you choose wisely and not just cheaply.
RIPSAW
Nov 6, 2015 04:36 AM
Tim1959
Jun 3, 2015 08:15 PM
bsmiley
Apr 27, 2015 01:27 PM
drbombay
Feb 5, 2002 02:38 PM
Grey
16
Jan 27, 2002 11:34 PM
