5w20 in D16Y7 ??
Old May 11, 2011
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
5w20 in D16Y7 ??
Look at attached picture
Apparently Honda says that running 5w20 in 6th gen civics is "acceptable", despite manual saying 5w30 & 10w30
-What could I expect in fuel savings going from 10w30 to 5w20?
-What differences in wear/engine life could I expect?
My engine likes 10w30 Chevron Supreme instead of 5w30... 5w30 causes some upper motor chatter when cold @ certain RPMs..
-Has anybody else done this?
Looks like 'djlunatic' has
Name:	honda engine oil application guide Honda0W20chart.jpg
Old May 11, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: 5w20 in D16Y7 ??
This has been killed on the forum... use 5w30 to prevent leaks and such... the advantage to 5w20 is slightly better gas mileage... so slight you won't even notice it. 5w30 protects the engine better and is less likely to leak. Your upper motor chatter is probably your valve clearances out of adjustment that is a seperate issue that you should get resolved
Old May 11, 2011
MelJ's Avatar
Trance Addict
If it gets too bad, it'll throw a CEL for running too rich or lean. Honestly, I just go by what the manual says to be on the safe side. Like tbohar said, the savings in fuel won't even make a difference.
Old May 12, 2011
OK thanks. Yeah I suppose it could instead be a bit of piston slap but I don't know how a heavier weight quiets it down. I had my shop do a valve adjustment a while back, the engine sounded the same after the adjustment.
Bruce2
Sep 27, 2015 08:45 PM
Bruce2
Sep 21, 2015 08:01 PM
Monty022581
Aug 31, 2015 08:32 AM
totravska
Aug 30, 2015 12:02 AM
