Helppppp!!!!
Old Apr 20, 2011
isaiddurazoo's Avatar
isaiddurazoo is an unknown quantity at this point
Helppppp!!!!
I have a civic with a d16y8 no vtec, and the oil pan just recently got a crack so I used jb weld on it.
That worked fantastic.
I refilled the oil.
Now it boggles all the way through when accelerating.
You can really feel it through 1000 -2000 rpm.
And also I have a really low idle.
I've been trying to diagnose it all day.
My ideas.
too much oil.
distributor cap.
02 sensor.
I already checked all the spark plugs and fuel injectors and they are working fine. I'm stuck.
Old Apr 20, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Re: Helppppp!!!!
I'm almost afraid to ask how the welding process was done. Where was the crack on the oil pan, and how did it crack?
Old Apr 20, 2011
Re: Helppppp!!!!
did you wait 24 hrs for the weld to cure?
Old Apr 20, 2011
Re: Helppppp!!!!
Yeah the welding is fine, the oil is fine.
Old Apr 20, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: Helppppp!!!!
Clean your throttle body and sensors. I don't think these two issues are related unless you let it run low on oil and damaged something internally. Zeferint JB weld isn't an actualy melting weld, it's just a product you apply to a crack that seals it up. Pretty good stuff actually
Old Apr 20, 2011
Re: Helppppp!!!!
Yeah that jb weld is a life saver.
Turns out the car is going into limp/safe mode because the crankshaft position sensor isn't working correctly.
Hopefully its just a wire. I'll be back in a bit to update.
Old Apr 21, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: Helppppp!!!!
It's probably the sensor itself unless it's not hooked up properly
tomasd15
Mar 12, 2012 03:33 PM
civiclover1991
Sep 13, 2010 02:15 PM
05civic
Dec 23, 2001 08:34 PM
