1997 civic coupe
Old Mar 24, 2011
heavyd21962's Avatar
heavyd21962 is an unknown quantity at this point
1997 civic coupe
I have acquired a 97 coupe, 1.6L. The previous owner had a different motor put in the car said it was from a 2000 civic. He said the repair shop changed manifold and was told it should work. I have since replaced the distributor, and plugs. I have fire but it will not start. There are no belts on the car and I am not sure if they have to be in place or not. Any info will help. The vin number on the engine is 1HGEJ8245VL11376, the car is vin number 1HGEJ8248VL108245. Again any help will be appreciated. THanks heavyd
Old Mar 24, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: 1997 civic coupe
you need the following to make the car run.
1) spark
2) fuel
3) timing
You need all 3 to get it running, if you have spark move onto checking for fuel, then onto timing.
Old Mar 25, 2011
RemyL31's Avatar
RemyL31 will become famous soon enough
You don't need any belts to run as they only run the accessories....alternator, power steering, a/c...
the water pump is run by the timing belt so you are good there...
Like previously said before, fuel and spark, but timing of when that spark is key..You replaced the distributor? Is it timed properly?
Old Mar 29, 2011
Okay, found out today that the ecu and the trans. are from the 1997 civic ex. The engine block has these letters stamped on it D16Y5. I believe I will need an adapter or the ecu from what ever car this fits. As best I can find it comes from a CIVIC HX ? Do not really have a clue and I am not familiar with the d16y5 engine. Thanks for the help and any advice will be appreciated.
Poopies
Apr 20, 2017 11:36 PM
miatabro
Jul 17, 2015 12:12 PM
oneheadlight
Apr 29, 2015 11:30 PM
shaejb15
Apr 26, 2015 07:44 PM
CapYoda
Nov 11, 2001 05:17 PM
