Warbling RPM at medium load
Old Mar 13, 2011
jammers's Avatar
jammers is an unknown quantity at this point
Hi everyone - First time thread poster, long time reader, LOVE the show.
Here's the deal: I have a '97 Civic HX (D16y5) that has had a long history of EGR system clogging and low EGR valve lift. I believe that the car still has these problems, but they have never really caused much of an issue before, so they persist.
Recently my Civic began to exhibit a weird problem where the engine RPMs warble at medium load. I can idle fine and I can rev the engine to high RPM without problem. It's the medium load condition where I run into issues. When at medium load, the engine revs up from around 1600 but then cuts out at around 2,200, then does it all over again, repeatedly.
I pulled a few CEL engine codes: P0130, 131, 132 (engine misfires on cyl 1, 2 and 3), I'm also getting that error code for the low EGR valve lift (P01431 I think) and I'm also getting some O2 codes. I'm not all that worried about the O2 codes because I suspect that whatever is causing the engine warble condition is also causing me to have a poor combustion (and therefore improper air/fuel ratio).
Has anyone encountered this before? Any possible theories about what may be at play here?
Thanks for your help!
Old Mar 13, 2011
Re: Warbling RPM at medium load
possibly the egr valve is fine and its the passages in the engine that are clogged.
Old Mar 14, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
check spark plug and wires
engine misfire means ur plugs r not igniting the gas in the combustion chamber
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
mistahlorax13
21
Nov 18, 2015 12:47 PM
Juanb24
Sep 15, 2015 12:39 AM
thaler4cuse
Sep 7, 2015 08:25 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
