Civic Aerodeck 1,4 IS - control power windows problem
Old Feb 19, 2011
alien's Avatar
alien is an unknown quantity at this point
Hi guys,
I have a problem with my Civic Aerodeck 1,4 IS (1998):
6 months ago, my windows began to do not work always. sometimes worked, sometimes not. a few days ago, suddenly, the windows motors doesn't work anymore.
I think that the "control unit power window" is gone....everything inside is ok, the contacts are like new.
I do not know how to control if this part is the problem. I wish to bypass the "control unit" but I do not know what wire to conect directly to the motor window to see if the power arrives.
can you help me? thanks!
ps- yes, I already controlled the fuses, are fine.
Old Feb 19, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: Civic Aerodeck 1,4 IS - control power windows problem
that control unit uses relays inside that box I would highly recommend that you do not bypass it as it will burn up the wiring and cause more headaches than you are willing to deal with.
Old Feb 20, 2011
alien's Avatar
I saw, I took a look inside the box, there are 2 relays ("down relay" and "up relay") - everything seems ok.
So, in this case, how can I control this unit to understand if is burned or not?
thanks!
Old Feb 20, 2011
Newfiedan's Avatar
you will need to find out which wires are the activation wires for up/down and then see which ones are the constant power wires to the module, you can test all of that with a test light then use jumper wires to see what is working and what is not. There will be 2 terminals for activation and 1 or 2 constant power wires as well as 2 ground wires for the relays.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
roverben
Jan 21, 2019 05:16 PM
bsmiley
Apr 27, 2015 01:27 PM
SSMatey
Apr 13, 2015 06:09 PM
BabyLX
Nov 8, 2001 09:25 AM
