96 Honda civic idling high problem
Okay so I got a check engine light for my map sensor so I replaced it.
I don't have a check engine light but now my car idles high at 2k rpm then it goes down to 1 then jumps back and forth kinda like it revving. And it's getting hard to shift, sometimes it grinds in reverse and first.... I have no idea what it could be!! Any ideas?
( Joined: Aug 2006
Re: 96 Honda civic idling high problem
Pull your throttle body and clean it with CARB cleaner the best you can.
Change your transmission fluid (with honda fluid) Is it MT OR AT?
Do an idle relearn (search site for "idle relearn")
Live for the Twisties
I would say your transmission syncros are starting to get worn if it's a manual, ultimately the only solution is a complete rebuild but you could replace the fluid with GM synchromesh to extend the transmissions life.
As for the high idle, start by cleaning the throttle body and IAC valve then doing a idle relearn. If that doesn't work you might need to replace the IAC valve.
Pr0n1s
Apr 30, 2015 03:08 PM
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
