Adding Keyless Entry to Manual Locks
Old Dec 5, 2010
Toid's Avatar
Toid is an unknown quantity at this point
I have been researching adding on keyless entry to my 1998 Honda Civic DX (2 door). The locks and windows are both manual. Through my research I am returning conflicting results. Some people say that you can add keyless entry to any car even if the locks aren't manual, while others state that it is impossible.
I should tell you that I just bought this car two days ago, so I am not real familiar with the inner workings in the door. The only thing I really want to do is get into my car without using the key and maybe locking the doors after I exit the car via the remote.
Therefore I pose three questions. Is it possible to get keyless entry on manual locks? If so, are you familiar with any kits that work well with the Civic (maybe one you have used or another member)? And Finally are there any other components I need to buy besides the keyless entry kit?
Thanks in advance
Old Dec 6, 2010
aj099's Avatar
aj099 is an unknown quantity at this point
Re: Adding Keyless Entry to Manual Locks
hey toid i have a 01 civic si with power locks but when i bought the car i had no keyless entry so i have been doing a bit of research and i found a kit on autoloc
check this link
http://www.thehoffmangroup.com/autol...powerdoorlocks
75$ for the kit
Old Dec 6, 2010
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
car alarm installation can put in ur motor for the locks and run the wires through the door. i seen this done on a 93 civic coupe dx
you can find the lock solonoid at any salvage yard
u probly need extra components but yes it can be done
do a little more research you can get there.
either that if u can take out the door panels and look at the lock mechanism
theres probly a spot where u bolt on the lock solonoid and run the wires through. good luck dont let others say that it cant be done
Old Dec 6, 2010
Toid's Avatar
Thanks for the information. I like the kit you showed me. I also found this kit at http://www.emiata.com/KEPL/HondaCivic.htm . I like this kit because it allows you to add a trunk kit as well as alarm if needed. The price is good as well. The site is a little outdated, but it is secured when you order. ANyone have any ideas if this is an alright kit for what I am doing? Or do you know if the kit you ordered allows a trunk kit? I saw you can buy the parts for pretty cheap ($15 I think).
Old Dec 6, 2010
i got the trunk kit for free when i order my alarm remote start for 120
i never intend to install the trunk
u just need to drill a mounting point and run the wires through
that website looks pretty good and it comes with manual
u cant go wrong give it a try
Old Dec 8, 2010
Steven21's Avatar
Steven21 is an unknown quantity at this point
Woah wait does your trunk use the wire to unluck? Cause i have keyless entry and remote start in my 99 dx and the *** hole i had install mine said they couldnt do the trunk
bluedoggy1
Jun 20, 2015 11:25 PM
Youshoe
May 22, 2015 09:36 PM
davidarenberg
May 16, 2015 08:45 AM
Shabba
May 13, 2015 10:55 PM
darwin-t
Apr 18, 2015 09:29 PM
