Door Actuator or Something else?
Old Nov 22, 2010
tjman982002's Avatar
tjman982002 is an unknown quantity at this point
So my wife's 2000 civic LX is having some door lock issues.
With the factor keyless entry the doors will lock but will not unlock.
While inside the vehicle, using the door lock switch, the all doors except the drivers will lock/unlock.
While using the key in the keyhole outside the vehicle I can lock all doors from the drivers door and unlock the drivers door.
Does this sound like the driver door lock actuator or something else?
Any thought or suggestions?
Thanks.
Old Nov 22, 2010
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
Re: Door Actuator or Something else?
Sounds exactly like a door actuator, put your ear up to the door when you try to unlock it, you may hear a "cluck cluck" sound that is the actuator trying to unlock the door. If you hear that its almost certainly the actuator. You can try taking it out and then cleaning the junk out of it but I've never found this to work for any car I've worked on - I end up replacing them.
Old Nov 22, 2010
Kennykid2002's Avatar
Kenny the Ricer
Most likely its door actuator
Thread on how to replace on a 7th gen:
Should be almost same as 6th gen
https://www.civicforums.com/forums/1...-actuator.html
First Car
Sep 8, 2015 08:54 PM
Brad Andrew
Sep 8, 2015 08:22 PM
redcloud
Sep 7, 2015 01:45 PM
Sep 3, 2015 07:01 PM
cecisd15
Aug 11, 2015 02:53 PM
