Stage 2 or 3 cam for D16Y8
Old Oct 7, 2010
Soldierboy87's Avatar
Soldierboy87 is an unknown quantity at this point
I am thinking of getting a stage 2 or 3 cam for my 96 Civic EX. What will I need to get so my engine will be able to handle it and where would be a good place to find these parts?
Old Oct 7, 2010
02civicsi02's Avatar
Low and slow!
Re: Stage 2 or 3 cam for D16Y8
Just go ahead and get the stage 3, you will need to upgrade the valvetrain with either the stage 2 or stage 3.
Old Oct 7, 2010
Mad Dog Tannen's Avatar
^IDK about that. Stage 3's are usually not very good for the street. They have a very high and rough idle.
Either way you should get a good dyno tune after installing either one. You also need stronger valve springs and retainers.
Old Oct 7, 2010
That's why I was thinkin about goin with the stage 3. Just didn't know if I'd need more parts for the stage 3. I just bought SRI and a Megan 4-2-1 header. You think Stainless steel springs and retainers would be good enough? I don't really drive fast but I do want the power to be there and I wanna hear her scream when I ask her to.
Old Oct 7, 2010
How much horsepower do you think I'd get out of a stage 3 cam, SRI, Cat Back Exhaust, Megan header, some type of engine management system(maybe hondata), upgraded intake manifold, and a bigger throttle body?
Old Oct 7, 2010
If you drive it on the street I would stick with the stage 2. You might need bigger injectors also. A good tune might compensate, but bigger injectors are the proper fix. I'm not sure what size would be appropriate.
Old Oct 7, 2010
Low and slow!
Ya the stage 3 cams do make a bit rough idle lol. But it will still be alright if he upgraded the valvetrain. But ya if you DD this car then stage 2 might be for you and you will still have to upgrade the valvetrain and will need a engine management. And I am pretty sure you will not need injectors. If you did need injectors you can just grab rsx-s injectors.
Old Oct 7, 2010
So you think Stainless steel valve springs and retainers outta do the trick right? Is that all I would need for a stage 2 cam?
Old Oct 7, 2010
I think the smart thing to do is upgrade my connecting rods too. I heard these are a weak point in this engine and I don't wanna take chances.
Old Oct 7, 2010
Low and slow!
I am not sure bout the d16y8 and the rods but i think you might be alright but if you want to go ahead and upgrade them then do it but it will be alot of work. If you do this yourself then make sure you go by everything that the manual says cause going in that deep is no joke.
Old Oct 7, 2010
I'll put the header and the SRI on myself but I'll leave the cam work, rod work, and engine management to the professionals. I'll be spending a lot of money so I wanna make sure it's done right. Will I need new (maybe lighter) valves or should the stock ones be alright? Sorry for so many questions but I know yall have a lot more experience than I do with all this.
Old Oct 7, 2010
I you don't need new valves at all. They would be a complete waste of money.
Old Oct 8, 2010
Low and slow!
It wouldnt be a complete waste of money cause valves are not that expensive. But it would help alittle especially if he went ahead and ported and polished his head, he would get better flow and torque.
Old Oct 8, 2010
So I've gone ahead and bought SRI and a megan 4-2-1 header already. Didn't buy the cam yet because I gotta find out what's the better brands for a stage 2 and where I could get one. I also gotta find out if i will need cam gears or if I can use the stock cam gears. I wanna get titanium springs and retainers but I'll wait till I decide on a cam first.
Old Oct 8, 2010
What i hear is that a K-Pro is must for stage 2/3 for D17A2 (best gains and idle). Not sure which system for D16 though, but you might better call Hondata for more info. They also talk about a VAFCII, but that was for turbos.
Soldierboy, PM Boomerman, i am pretty sure he might have some more info even if he have a 7th gen, i am pretty sure he worked some 6th gen as well (friends' and others.).
Old Oct 8, 2010
Boomerman is not a member. I just looked for him and did not see his name.
Old Oct 8, 2010
he is in here
https://www.civicforums.com/forums/7...ot-suck-4.html
Old Oct 8, 2010
post #106
Sorry, bomerman19 is the username...
read there and you will see how much he knows. Ignore all the first 3 pages, BTW, only bickerings there. things get better from page 4.
Old Oct 8, 2010
Porting and polishing and bigger valves hardly does anything on these 16 valve engines. They already have a efficient design. You can actually hurt performance if you port them the wrong way. If you do get them ported w/bigger valves (which I think is a waste of money) then go to someone who really knows the engine well.
Definately get titanium retainers and stronger springs with those cams!
Old Oct 10, 2010
Ok. Found a stage 2 Tuner cam from Jassproparts for $250.00 w free shipping. Does that price seem about right to yall or do yall think I'm gettin scammed. These are the advertised specs.....Intake (lift / duration) 0.432" / 235 Exhaust (lift / duration) 0.436" / 223 How does that look to yall?
Old Oct 10, 2010
It's a BLOX camshaft. Is that a good company?
Old Oct 11, 2010
Crower, buddy, Crower.
Just stop being stubborn and check here, info about stage 1, 2, 3 and BLOX. This is the site i told you before, and the BLOX info comes from Bomerman19, who i told you to PM. Geez!
http://www.***********.com/forum/showthread.php?t=20154
OK, it does not work.
type 7th gen honda in the ****, without spaces
Old Oct 11, 2010
jamis33's Avatar
You Stay Classy, San Diego
or for d16 bisimoto!
Old Oct 11, 2010
Not being stubborn....just wanna make sure I'm doing it right. I did pm Bomerman19 and he did tell me I can use the stock cam gear because I can't get any more power with a SOHC setup. He also told me his specialty is the 7 gen. Every time someone types a website for me to go to all I see is ***...stars in the place of words. Maybe if you skipped a space somewhere in there I'd be able to see it...idk. Thanks for the help skaidoji. I do appreciate it.
Old Oct 11, 2010
yes, sorry about that, guess that is because that site is a riv-al one...
Old Oct 18, 2010
No prob man. I've gone ahead and bought the Crower Stage 2 NA cam and Crower Titanium valve spring and retainer kit. Now I just gotta figure out what kind of engine management to get. I think there are different hondata tuners and I'd like to know exactly which one I'd need. I will get it tuned once I get that.
ricer_em2
May 11, 2016 08:09 PM
winanthony94
Sep 25, 2015 09:05 AM
chiquita.banana
Sep 24, 2015 09:42 AM
OptimisticWay
Sep 18, 2015 09:37 PM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
