Can I use this head?
Old Jun 3, 2010
jako's Avatar
jako is an unknown quantity at this point
I'm looking to replace the head in a 96', with a 16y8 block.
The one on the bottom of the photo came out of the car (stamped 96')and has a bad cam.
The one on the top is stamped 99'.
Would this swap work? What gasket kit would I need?
Name:	2010-05-25 11.37.58.jpg
Old Jun 4, 2010
ScottDR's Avatar
ScottDR will become famous soon enough
Re: Can I use this head?
If it's the same donor engine (d16y8 head) you will be fine. You will need a head gasket, intake manifold gasket, cam seal and valve cover gasket set while you are at it and you are set.
Old Jun 5, 2010
BlueEM2's Avatar
Whachya lookin at?
That is a D16Z6 head and should be a direct fit replacement for yours. You can use either head gasket. The head bolts are different length though, so if your putting a Z6 head on, use Z6 head bolts.
Also, I think the distributor does not line up properly, so you have to get a hold of a Z6 distributor and install its internals into your y8 dizzy in order for it to line up and work.
I hope this helps. I have heard of people having trouble with the swap but if I had the head already I'd try it. Good luck. Oh, also use the Y8 timing belt.
Old Jun 5, 2010
jako's Avatar
O.K. nother dumb question... I have a gasket kit for a "D16y7", will that work?
Old Jun 6, 2010
BlueEM2's Avatar
Whachya lookin at?
Should work yea... Why so many mismatched parts??? If you already have the gasket slide it on the head make sure everything lines up, then take it off and slide it on the block and make sure everything lines up... just to be 100% sure.
Old Jun 6, 2010
jako's Avatar
Obviously I'm not normally a Honda guy, (old VW's are my thing) the civic is my son's.
I got the replacement head off E-bay, the gaskets I ordered from the LPS for a 96', and that's what I got.
If I open the package... no return.
My confusion comes from the fact that I don't know how to identify the various
heads. Is the number on it somewhere that I don't see?
Anyone got a link?
Tomorrow I'll try to exchange the gasket kit for a D16Z6.
Thanks for all the help!
Jack
Old Jun 6, 2010
BlueEM2's Avatar
Whachya lookin at?
You probably don't need to exchange the gasket kit. I only did a visual inspection of the head. I'm about 98% sure that it's d16z6. Often the engine code is stamped on the block, but I don't think it's stamped anywhere on the head. Make sure you get z6 head bolts or your going to be in a lot of trouble. Or get ARP head studs.
7thgensurvivor
Aug 26, 2015 06:17 PM
hoofboy
Jul 17, 2015 04:27 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
Ccoop87
Jul 9, 2015 03:26 PM
