Neon License Plate Frame Install
Old Dec 1, 2009
SirCharlo's Avatar
SirCharlo is an unknown quantity at this point
Hey guys !
Just got a neon license plate frame. Instructions were a piece of crap, so i searched the web and found an eHow article about it.
It says: "Pop the trunk and locate the tail light wires. Use the wire strippers to strip a part of the red wire down to bare wiring."
OK, where the heck are these "tail light wires" ?
Are they in the 1cm-thick black wire-thingy that runs along the trunk cover ? Do i just cut it open and wham-bam there's the red wire ?
And where do i route the license frame wires so that they do not show ?
Thanks for not mocking the n00b question.
Old Dec 1, 2009
Re: Neon License Plate Frame Install
well if you pull off those carpet pads on the side (inside the trunk), you will see the rear of the taillight. take out the parking light socket and there is your wiring. you may need to cut off the black loom covering to actually see the wires. and there should be some opening to get the neon wires inside thru the trim piece just above the plate spot.
Old Dec 1, 2009
SirCharlo's Avatar
Okay, so i removed the side carpet and i took a quick peek.
I guess you're talking about the four wires that run into the light via a harness and are covered by a huge snake-like protector ?
One of the wires is half red half black, so i would just connect my wire to that ?
I don't see no opening
(btw, not my ride, i wish it was )
Old Dec 1, 2009
if thats how your plate light looks, you can take off the two screws and slip the wire inside the hole leading to the trunk. it will get smashed a bit but should be fine with the plastic around it. then just run the wires down the trunk following the original wiring thats already there, and to the taillight. find the bulb for the park lights, and tap the neons to the + and - wires, usually red and black underneath the black cover. you prolly need to cut the cover, but be careful not to damage the wires.
but i just remembered, i dont think that will work cause when the trunk is open it will pull the cables. how about those hollow license plate bolts? i think that would be easiest. they usually have em at autozone, they are the led bolt lights and the actual bolt is hollow so you can run wires thru it.
Old Dec 2, 2009
SirCharlo's Avatar
Hey gearbox !
Thx for the reply.
Just got majorly flamed over here: http://honda-tech.com/showthread.php?t=2689579
I'm glad to see that not all forums are like this
So, I finally drilled a hole in back of where the plate mounts, so it's invisible. I routed my wires in there, perfect !
Now, I just need to hook up the red wire on the neon to the red one on my license plate light. Plus screw the black wire on my neon to the trunk body somewhere, to ground it. And that should be good !
Thanks for all your help !
Old Dec 2, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Oh no. If you drilled a hole in your trunk and it's not water tight, you're going to have a very wet trunk when it rains. It doesn't matter how small the hole is nor how well you think the wire blocks it, water will get in there.
And I won't flame you but I don't like those license plate lights.
Old Dec 2, 2009
yeah hes right. a simple fix would be stick a small ball of that 3m windoweld stuff (flexible goo used to seal headlights) in the hole, or even a lil bit of silicone (messier and harder to remove later tho). make sure you paint the hole edges first and let it dry 24 hrs before sealing.
Old Dec 3, 2009
SirCharlo's Avatar
Cool Re: Neon License Plate Frame Install
Hey guys !
My installation is completed, everything works mint.
Thanks to your tips, I successfully sealed up the hole, so as to make it watertight.
Thanks alot for all your help !
Old Dec 3, 2009
any pics?
Old Dec 3, 2009
SirCharlo's Avatar
My ride is all stock..
No mods at all ! (Except for the plate neon... )
Didn't even change the factory radio yet...
I'll upload pics when i can, but don't expect much
Old Dec 3, 2009
gotta start somewhere. my first mod was blue led washer nozzles and i installed em myself!
Old Dec 3, 2009
rednwhite04's Avatar
rednwhite04 will become famous soon enough
HT is gay!
Old Dec 3, 2009
SirCharlo's Avatar
HT - Honda-Tech ??
Why didn't I think of the washer nozzles...
I might give it a whack
Old Dec 4, 2009
DeX's Avatar
DeX
Canadian, Eh!
gearbox, stop giving him ideas....
Old Dec 4, 2009
SirCharlo's Avatar
A little idea is a dangerous thing !
Old Dec 4, 2009
BlueEM2's Avatar
Whachya lookin at?
Why not get LED neon light strips and run them all around the seams... like the hood and trunk seams. And of course the doors... Just remember to make them green, red, and white. That way you look like a Christmas tree rollin' down the road
We want some pictures, pics never hurt ! Sometimes a stock car is the nicest car
Old Dec 4, 2009
SirCharlo's Avatar
Hmmm... Trying to think of what i would look like with blue and purple led strips all over... Naah
Okay, here are the pics !
Nothing big, like i said, but i like it
Old Dec 4, 2009
nice man i like it. my friend had a pink one til she got pulled over and cop said it has to come off lol. so enjoy while you can. i had blue underglow neons and got pulled over the first night i had em on
Old Dec 6, 2009
SirCharlo's Avatar
lol that sucks
Actually, i checked my local laws, and license neons as well as underglow neons are both legal here, as long as they don't pulse or pivot.
Hrddrvs
Apr 11, 2015 11:22 PM
technosilver
Nov 16, 2001 07:00 PM
wawacito
Nov 5, 2001 03:32 PM
