Wiper doesnt work
Old Sep 18, 2009
Sasch91's Avatar
Sasch91 is an unknown quantity at this point
Wiper doesnt work
Hey guys. I have a little problem.
One day i started up my vehicle and i was driving and while i was driving it was dripping a little bit outside so i decided to turn on the wiper with the slowest speed. . . Nothing. The wiper did not even move. The second and third wiper speeds are working. I decided to check the fuses. No fuses are burnt. What else could be my problem? I would be happy about every answer i get.
Sasch
Old Sep 18, 2009
johnlam1688's Avatar
johnlam1688 is an unknown quantity at this point
Re: Wiper doesnt work
How old is your car? May be the tread on the wiper itself not hook with the motor.
It happened on my car before. Double check the one that is not working. If both are not working, you may have to bring to the mechanic or tech.
Hope this would help.
JL
Old Sep 19, 2009
Sasch91's Avatar
both wipers arent working. is it possible that the switch isnt working?
Old Sep 24, 2009
dnice78's Avatar
dnice78 is an unknown quantity at this point
I have the same problem only mine works sometimes and doesn't work at other times... also my washer fluid won't pump. So i'm thinking it might be a bad relay?
Old Sep 24, 2009
do you hear the buzzing of the pump? if so, it could just be clogged nozzles or lines. if you dont hear anything, washer pump could have died.
pratik05
May 15, 2015 01:54 PM
autowill
May 15, 2015 11:36 AM
shindrome
Exterior
May 5, 2015 02:50 PM
ORskier
May 3, 2015 12:54 PM
Elusiv1
Nov 9, 2001 02:44 PM
