[Help] Transmission problem?
Old Aug 21, 2009
iflyimpilot's Avatar
iflyimpilot is an unknown quantity at this point
Hey guys,
New to these forums, and in need of some help so please bear with me..
I have a '99 Civic LX 4door (automatic) -- around 102k miles
This problem seems to happen when I have it on D4. I notice it when I'm cruising between 30 and 40 mph, 4th gear, steady on the throttle. I would hear a slight grinding noise seemingly coming from under the engine compartment. It stops when I let off the gas, or push down on it. At times, the car would also run rough until I make the same action (let off the gas and/or push down). The two symptoms I've mentioned sometimes occur together or one at a time and at different orders. I've experimented with it before and put it in D3 and never had problems (of course not going so fast as to redline the RPMs). Could this be a transmission problem?
P.S. -- I've had this "symptom" for a few years now, but it temporarily went away after a family friend who's a mechanic did some maintenance on it years ago. Unfortunately I don't know what he did exactly since I was on vacation at the time.
I hope I explained somewhat clearly and that someone can help me.
Old Aug 21, 2009
Awjvail's Avatar
Awjvail is an unknown quantity at this point
Re: [Help] Transmission problem?
Perhaps part of that maintenance was changing the transmission fluid?
Try changing that.
MajTom
Jun 2, 2015 11:48 AM
Schneiderman
May 24, 2015 01:14 PM
cruisers10
May 12, 2015 10:46 PM
Jessica Leung
May 5, 2015 05:12 PM
markp94
Apr 30, 2015 09:19 PM
