Nothing Happened
Old Aug 3, 2009
crazy canuck's Avatar
crazy canuck is an unknown quantity at this point
Nothing Happened
Well I lowered my car this Saturday,or at least I thought I did.I bought some 1.5inch drop springs called MIRacing.I put them in and my car is still fairly high.The ride has stiffened up but that is it.Will these springs settle down or not? Do I need to buy some other brand? HELP.......
Old Aug 3, 2009
fracas's Avatar
fracas is an unknown quantity at this point
Re: Nothing Happened
are you sure you put the front springs on the front and the rear on the rear? If so you just need to ride on them some. They are new so they will be real stiff.
Old Aug 4, 2009
I put the heavier spring on the front and the smaller gauge on the back!!!! That is what I was told to do from the local shop!!!!
Old Aug 4, 2009
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Springs take time to settle. I think up to a week, someone can correct me on the time.
Old Aug 4, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
They could also not be seated right or be upside down. Is there any writing on the spring jacket that you can read? It should be right side up. Also you have have needed to modify the bump stops on your factory shocks. I hope you bought a camber kit and got a wheel alignment as well or you'll be making another thread in 2 months about faulty tires wearing too fast and all your rear end suspension parts rattling to hell.
Old Aug 6, 2009
What do you mean buy or how do I modify my bump stops on my shock?When I was putting the springs on I pushed the shock down and it then pushed up to the stock height.They are seated right and are in right side up.They would only go one way,top is to wide for bottom.It handles better just didn't drop.
Old Aug 7, 2009
fracas's Avatar
Give it time. Your cars weight will make the springs drop. They are real stiff and need to work themselves down from the weight.
Old Aug 7, 2009
DeX's Avatar
DeX
Canadian, Eh!
Did you read the instructions for installing them? Some springs require the bump stops on the stock struts to be modified. They're usually pretty high to stop the car from hitting too low because of how bouncy the springs are. When you put in a different spring, you can cut the bump stop in half so the car won't hit until it gets to a lower point. It should look like a rubber cup on the end of your strut. Check and see if these need to be modified with your application.
Old Aug 7, 2009
Thanks for the help and suggestions!! I came out this morning and measured my car and the car has dropped 3/4 of an inch since a couple of days ago when I measured then..Hope it drops a little more.Now I need to find a nice sounding muffler.One with a deeper sound.Any suggestions?
Old Aug 7, 2009
DeX's Avatar
DeX
Canadian, Eh!
Good sounding mufflers don't exist. They're mufflers......that's what they do.....they muffle sound.
cwisenbaker06
Aug 19, 2015 04:29 PM
alaga
25
Aug 13, 2015 04:42 PM
andyandyy
Aug 4, 2015 06:37 PM
cukaracha
Jul 17, 2015 05:48 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
