climate control lights
Old Jul 24, 2009
stopspazinout's Avatar
stopspazinout is an unknown quantity at this point
ive tried searching the forums but the search feature seems to be down yet again. just wondering if anyone knows how to change the lights out that light up the climate control on a 97 civic
Old Jul 24, 2009
Re: climate control lights
you have to remove the whole middle console and then the climate controls have twist bulbs in the back. you can buy the naked bulbs at the store and wrap them onto the original base, or buy the whole bulb and base from honda. btw for the search function, be sure you are searching "titles only" instead of "entire posts" which will take forever to search millions of posts.
Old Jul 25, 2009
so they're not like 194 bulbs that just slide into a socket that twists in the back? if not could you explain wrapping the bulb in the socket?
Old Jul 25, 2009
well its a smaller bulb with wires sticking out, you have to wrap them around the bulb holder. they are still the twist and remove base, but you gotta dismantle the bulb by unwrapping the wires around the two sides and then install the new bulb the same way. youll see once its taken apart and then you can compare the bulb to find the right one at the store.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
MamaBear2015
May 27, 2015 12:04 PM
cukaracha
May 16, 2015 02:11 PM
bsmiley
Apr 27, 2015 01:27 PM
