98 Civic EX idling difficulty !!Help!!
Old Jul 5, 2009
98sLicKvIc's Avatar
98sLicKvIc is an unknown quantity at this point
Hey guys i'm derek i drive a 98 civic ex, 5spd, with a D16y8, completely stock minus an AEM short ram intake.
For about 3 weeks my civic has been idling oddly.
After its warmed up and the car is in motion i will put in the clutch to coast and the RPMs will stay stuck at 1.5 - 2 and i have to slightly rev the motor to "un-stick" it.
When i am stopped the RPMs will again stay stuck at 1.5 - 2, but only for about 5 seconds before dropping almost to zero.
On rare occasion the motor will idle normally (700-900 RPMs) and it will be fine. but this is only when it is not moving.
i'm not sure which diriection to go. Any help would be GREATLY appreciated.
thanks
Old Jul 6, 2009
98sLicKvIc's Avatar
Re: 98 Civic EX idling difficulty !!Help!!
There is no way someone on this forum has NOT had this problem.
ANYONE out there??
Old Jul 6, 2009
im sure its an intake system problem. the idle air valve and fast idle thermo valves located on or around the throttle body can get clogged with carbon buildup and produce the sticking you mention. just unbolt all the lil valves on the throttle body or intake mani and flush them out with carb cleaner. may as well replace the pcv valve too.
Old Jul 7, 2009
98sLicKvIc's Avatar
thanks it turned out to be the PCV valve!!!
mikemc422
Aug 9, 2018 05:41 PM
beneditti
Jan 15, 2016 12:31 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
