Car doesn't start...
Old Jul 3, 2009
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
I tried to start the old girl the other day and she wouldn't start. It will turn over but it just won't start. Fuel pump is working. I thought it was the fuel filter, so I replaced that and she's still not running. Any other suggestions of things I could try?
Thanks
Old Jul 3, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Car doesn't start...
6th generation? Common thing is the fuel pump relay, they replacing that or seeing if it's getting power to it. And even if the fuel pump is coming on and the filter is clean, it doesn't mean it's actually sucking fuel through, it could still not be getting power. This happened to me on a Cavalier, pump was fine, filter was fine, it just wasn't getting suction so we replaced the whole unit and it was perfect.
But my bet is the relay, seems to be the problem every time.
Old Jul 3, 2009
Mavrick272's Avatar
It is getting spark too, by the way, I checked that
Well, my friend and I were replacing the filter and we forgot to put one of the washers on and I clicked the ignition to the on position......and we had a gasoline fountain in the engine bay
I'm pretty sure it's getting fuel
Old Jul 3, 2009
check compression. is fuel actually getting thru the fuel injectors? sometimes they can be clogged or not produce a mist, which will cause problems starting.
Old Jul 3, 2009
Mavrick272's Avatar
How would I go about checking compression/injectors?
Old Jul 3, 2009
compression tester is $40 at the store, or a shop can do it. each cylinder should be around 130-160 psi and all four cylinders need to be consistent like between 5 psi of each other. if one is low, theres your problem and the motor will need rebuilding. fuel injectors are much trickier, since usually you need to get new ones or send the old ones away to be cleaned and blueprinted.
Old Jul 7, 2009
Mavrick272's Avatar
My dad came out the other day and fixed her in 2 minutes. He looked under the hood, saw 2 wires weren't clipped together all the way, and ta-da! she's fixed.
Here's a picture of the clip that wasn't fastened. Can anybody tell me what that thing is in the second picture?
ID:	76873   Click image for larger version
Old Jul 7, 2009
the big round thing is prolly cruise control module. you can see a throttle cable coming out the left side. not sure what that plug is for tho, could be anything.
Old Jul 8, 2009
Mavrick272's Avatar
Interesting, seeing as the cruise control doesn't work...yet when that clip on there was unplugged, the car wouldn't start...
Anyways, thanks, I was just curious
sharp66
31
Jun 12, 2022 08:45 AM
mistermenphis22
Apr 3, 2016 08:06 AM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
tylerginevan
Apr 27, 2015 12:29 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
