97 civic idling like crap
Old Jun 16, 2009
chris694205's Avatar
chris694205 is an unknown quantity at this point
hey guys i own a 97 civic 1.6 vtec auto... recently the SES light came on and is hunting for idle between 1500 and 2000 rpms... i believe the code is a p1337 which is the idle air control valve.... should i replace the valve or is there something else i can do
Old Jun 17, 2009
sql_civic's Avatar
Re: 97 civic idling like crap
Code P1337 indicates a problem with the Crankshaft Speed Fluctuation (CKF) sensor circuit. Are you sure you have the right code?
There are several things that can cause a hunting idle. If you suspect the IACV, you can remove it and clean it out with brake cleaner. There's a screen in there that can get clogged up.
Old Jun 18, 2009
yeah i messed up... it was a p1509.. i did take my iac apart and i dont think there was a screan in it
Old Jun 20, 2009
sql_civic's Avatar
OK, the P1509 indicates IAC Valve Circuit Failure so it's something to do with the wiring. Check if you've mixed up the IACV and TPS plugs. They have the samt plugs. (Or was it IACV and MAP?) Anyways, check f the right plug is plugged into the IACV.
mikemc422
Aug 9, 2018 05:41 PM
tylerginevan
Apr 27, 2015 12:29 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
